have had the clip+ for a few years now and all of a sudden when I hit the home key, it went to the settings menu instead of the music menu. Now it won’t go anywhere else. I have tried resetting it. I have updated the firmware. Anybody got any other ideas?
thanks
And pressing the up or down button to move between the Main Menu options doesn’t do anything?
In the worst case, you could try a reformat of the player–that sometimes will clear up unknown issues (altho, uncertain if it would have any effect here). Remember to transfer any content you want to keep to your computer first.
