Highlighted
Newbie
VBR sound glitch
I got a set of audiobook encoded in FhG encoder which suppose to be the best encoder around.
But playing it on Sansa Clip produce a constant stream of voice glitch.
I listen the same file on my VLC player, they sounded just fine.
I have read this could be because Sansa Clip + doesn't work well with VBR file.
Is there a fix for this problem?
Highlighted
SanDisk Guru
Re: VBR sound glitch
FhG is not the best encoder around....it's not even the best MP3 encoder.... LAME is.
And the Clip+ works fine with VBR files, I have a ton of them. Maybe check your filesystem for errors?
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
Highlighted
SanDisk Guru
This is hilarious....a case of he said/he or she said.  "oh my I'm using the best encoder around, so that can't be the issue".... Ha Ha Ha....'Try my encoder...for it IS the best around'.....Geesh...
What a load.  I've used plenty of FhG files with my Sansa products without any issues whatsoever.  My guess that there is something contained in the files that the Clip doesn't like.
The issue at hand doesn't have a thing to do with which encoder is the best.  Providing the encoder is doing it's job properly, the Clip shouldn't care.  Let me repeat...I have hundreds, maybe thousands of FhG files that play perfectly with the Clip.
Now I'm going to encode some stuff myself, with the true best encoder....Nero Digital....  Ha Ha Ha Ha Ha.
Did I just say that?
"Before I sink into the big sleep...I want to hear the scream of the Butterfly"
Highlighted
SanDisk Guru
 I didn't say "try my encoder"....just that mine was better! Smiley Tongue
 I have a lot of FhG files too, and they seem to play just fine on my players too. That's why I suggested scanning her filesystem for errors.Smiley Wink
 I don't have that many, but the ones I have do seem to work just fine.Smiley Wink
Yes, I think you did!:Smiley Surprisedsmileyvery-happySmiley TongueSmiley Very Happy
