Highlighted
Newbie
Accepted Solution
Using the Sleep power-off option
I have recently bought a CLIP mp3 player.  I am trying to figure out the Sleep power off option.  I have used it successfully timing  the CLIP to switch off after 60 minutes.  However, after switching it off and some hours later switching back on again, it seems to have defaulted to a state in which it has lost the Sleep-power off mode.  Does anyone know whether it is meant to default to a state in which neither the Automatic nor the Sleep power off mode is programmed?
Highlighted
SanDisk Senior User
Re: Using the Sleep power-off option
Welcome to the forum spindrift,
I haven't tried the Clip's Sleep function (and I can't test it right now), but I think it's meant to be one-shot; you'll have to reset it every time you need it. In fact, all devices I've seen work this way (TVs, VCRs, etc.)
Auto-generate folder playlists for the Clip: AutoM3U v1.1
Highlighted
SanDisk Guru
I have used it too. Question is....are you falling asleep to music, or the radio, or a podcast/audiobook? I quite often fall asleep to podcasts....if you do that, your auto-power-off interval will come into play. Power off shuts the Clip down after a user-selected amount of time once it goes into pause mode(like when a podcast is over) and that time remains perpetually in effect(also useful on the FuzeSmiley Wink). The sleep timer, on the other hand, used for music files or the radio....that you have to reset each time you use it. Hope this helpsSmiley Very Happy
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
Highlighted
Newbie
Thanks Marvin. That fits precisely with what I have found by trial and error.  Fact is tho' the full pdf. user manual should make that clear and it does not as someone else has remarked on this forum.
Highlighted
SanDisk Guru
Well, alot of people don't read the instructions at all. I just briefly skimmed through them myself, but since I'm only working part-time I've had plenty of time to experiment. Also I got the Clip a couple months after I got my Fuze, so I was no longer a complete newbie to the MP3 scene at that point, which helped. In general, these Sansas are pretty user-friendly though, don't you think? Smiley Very Happy
Highlighted
SanDisk Guru
The sleep mode works for the currently selected interval, until the device is automatically powered off.
Upon starting up the Sansa later it is reset, and available under the Power settings selection once again.
Bob  Smiley Very Happy
Highlighted
Newbie
The CLIP would win prizes for its user friendly interface.  I have had a different branded MP3 player for two years or more and have never really used it because the user interface it seems to me, was designed to prevent anyone actually using it.  It has all the features found on the CLIP but behind such a wierd selection menu, very difficult to access.  I am an official Wrinklie these days and use the mp3 player for the night hours when I am not sleeping.  I find that by listening to something on the CLIP I get back off to sleep.  Strangely I find the most effective cure for insomnia are speech broadcasts and especially current affairs stuff with political comment!
Highlighted
SanDisk Guru
On that thought, we could rename the function "fillibuster mode".
Bob  Smiley Tongue
Highlighted
Newbie
Had to register to reply to this (STUFF your silly little password requirements, SanDisk)
So if I understand this,
  • Turning on the "Sleep" function means that you want the Clip to shut off after a certain interval, as if you were going to sleep and wanted the unit to turn off after you fell asleep, and
  • When "Sleep" is "on", then autopower sets the interval after which the unit shuts off.
This implies then, that
When "Sleep" is set to "off", then Autopower does nothing regardless of setting.
  1. The manual ought to SAY something like that, but since it doesn't, does that accord with everyone's experience?
(I had another make of MP3 player that would, if not playing anything, power itself off after (it said) ten minutes. Turned out it was 3 minutes, not ten, which I couldn't live with, but never mind.)
  1. Does the Clip power itself down if not playing anything, after X minutes?
  2. What's the difference between "not playing anything, backlight off" and "powered down". Is there a difference at all?
  3. Can the power-down interval that isn't "sleep" be controlled in some way?
Highlighted
SanDisk Senior User
Welcome to the internet, and a SPAM-free forum. Smiley Happy
I don't use Sleep mode, so can't help you there.  The Clip auto-powers off after a set time without using Sleep.  Running through the options now...
Yes.
Settings|Power|AutoPower: Default is 1 minute, but it can be set to 1/5/10/20/30/60 minutes.
By the way, Settings|Power|Sleep can be set to Off/10/20/30/45/60/90/120 minutes.
Not playing anything, backlight off - means it's still turned ON, waiting for input.  If nothing happens in the prescribed time selected above, it "powers down".
Once it powers down, you have to turn it back on (let it "boot up" again, and it takes between 5-10 seconds) before you can input anything again.
Described above.
By the way, thanks.  I've been mildly complaining of the 1 minute power-off time for quite a while now, so I switched it to 5 minutes while looking through this stuff, we'll see if I can handle that better.  I don't want to go too long because I'm in the habit of turning off my Clip by just pausing and letting it auto-power down.
Hope this helps.
