With 3 operating systems–Windows XP, Vista and 7–and 4 computers, I’ve never had an issue with Windows recognizing my Clips and just plugging and playing. Perhaps the fact that I always set the players to USB MSC mode and keep things simple helps?
I have been reading these forums trying to solve the problem without having to post but I can’t figure it out. I have the clip 2 gb and I have no music in my music folder. Since I bought the clip I have used it in MSC. I put it in the other options ( auto and MTP) but my computer will not even recognize the device. In MSC, it shows the device and the folders but not the files. I have gone in and opened all hidden folders. No change. Will updating the FIRMware have any affect on this. I should be running wmp10. Any other tips would be great. thanks
Updating the firmware will not have any effect. Your computer can only see files added while the player is connected in that same mode. Sounds like at some point (probably using Auto Defect mode) you transferred some music to it. Auto defaults to MTP mode whenever it can. Now it won’t connect except in MSC mode and it can’t ‘see’ those files.
I’d recommend formatting it (the player) and re-loading your content in MSC mode.
