SanDisk Professor
Re: Sansa Clip+ Offers Big Sound & Tons of Features in a Tiny, Stylish Package
@JK98 wrote:
For nimh rechargeables the power rstio for leading edge AA/AAA batteries is 2.9( 1000 mah AAA, 2900 mah AA).
For alkalines the ratio is around 2.5. The AA is smaller in power per volume, as the AAA has more overhead per unit of power for packaging.
 OK.. I haven't been following the AAA market recently... last I saw there were only 650mah.
 It's more than just a smaller battery has more packaging overhead.  AFAIK AA's are the most optimized because they sell the most of them.  NIMH D batteries are over 6x the volume of AA's but only 3.3x the capacity at 10 AH (Duracells)
SanDisk Guru
"It probably is what they meant. I'm just pointing out that inserting thousands of songs in seconds isn't the same as listening to them (the wording they used) as soon as you're done inserting if you have to wait a few minutes for the refresh."
I haven't tried a Slotradio card, however I imagine that there would be no wait for a database refresh. I would love to see the option to disable tag browsing in the Clip+ and Fuze, so that cards can be swapped without any delays to refresh the database. I hope we will see this in the next firmware update. The ability to disable tag browsing would also make Slotmusic cards more desirable, as one could remove a Slotradio card then go right to listening to a regular card without any delay.
Will Sandisk have 400 or 500 song Slotradio cards that sell for $20 or less? One web page I saw hinted at the possibility of 500 song cards. I doubt I would spend $40 or $50 for a 1,000 song card, but might buy one or more 400 or 500 song cards if they are priced at $20 or less.
SanDisk Guru
Excellent idea!
SanDisk Guru
Would be interesting to see if SanDisk would add the feature to allow the user to de-evolve the player back to a folder-based player ...
SanDisk Senior User
You would lose folder browsing too then. It actually uses the database for that, it's not actual storage-level folder browsing.
SanDisk Professor
 Well, yeah, fix that part too.
SanDisk Guru
[ Edited ]
"You would lose folder browsing too then. It actually uses the database for that, it's not actual storage-level folder browsing. "
If that is true, then it really sucks. Why isn't it storage-level folder browsing? Unfortunately I think you may be right about this though, as I was using my Fuze last night in folder mode, and two files in a folder on the player were in reverse order from the way they appeared in the folder on the pc. I still can't understand why. I will watch for this.
Message Edited by JK98 on 09-02-2009 01:45 PM
SanDisk Guru
Is the idea here that the database loading algorithm might load the files by creation/modification date, causing the files to not be displayed in alphabetical order by filename?
Maybe it is storage-level folder browsing, and the firmware simply sorts by some other file attribute than filename (why, I don't know).
SanDisk Guru
The files that were switched in order had names that were the same until the 20th charachter. Windows dealt with this properly, but the Fuze had them in the wrong order. I guess the Fuze doesn't look at the full filename, or even the first 20 charachters.
Newbie
I'm in the market for a MP3 player to take to the gym, so I would also like a FM turner on it. The sansa clip+ was recommended.
When you download music, do you put it on a sd card first?, opposed to my a windows library?  What about other free download music sites... can they be used as well?
This forum did not speak highly of the accessories for the sansa clip+. What accessories are available for the Sansa Clip+?
Is the Sansa Clip+ a better purchase than the Ipod Shuffle? How comparable are the two?
Any type of tutorial video would be helpful.
Thank you.
