It won’t turn on. But when i plug it it turns on. can copy files. But when we unplugs it wont start up!
I reset’d it but didn’t work!
Plus help
Plus help
可能是电源键坏了吧
再重刷固件试试,:smileyvery-happy:
Try updating the firmware When the player is connected to ur PC in MSC Mode.
To connect it in MSC mode:
Follow the link to update firmware:
If this is one of the original Clips (with the round, lit scroll wheel and wimpy clip on the back), the battery lead wire has probably broken off at the connector to the battery. This was (is) a common problem; the soldering at the factory left much to be desired in some cases.
If you want to try and tackle it, and have a small-tipped soldering iron, you can probably fix it yourself. The hardest thing is cracking the case open without damaging it and getting it put back together again. Click here for a disassembly guide with pictures.
If you don’t feel confident in doing this, transfer everything off of it and save it on your comptuter (for later), bid it a fond farewell, recycle it responsibly and get a new player.
And if soldering concerns you, you also can use conductive glue to get the lead back and attached to the battery. Available in electronics parts stores.
You may also refer to this step by step guide guide on how to batch convert PLS to MP3 audio format at http://www.ecouponcode.org/how-to/pls-to-mp3-converter.html
This guide also helps to convert PLS to WAV, WMA, AAC, M4A, AIFF and etc.
