Sansa Clip 2GB - My Rhapsody To Go Tracks Won't Synch
I use Rhapsody to go service.  I was told the sansa clip supports Rhapsody To Go…however, when I try to transfer some songs over to the sansa clip, everything errors out except for songs that I purchased.  help!
Please use the devices Format command to reformat the player.
Unplug the player from the computer and turn it on.
Go to settings > Format   Confirm  Yes
The player will reformat
Reconnect the player to Rhapsody.
The tracks will transfer properly .
Thank you so much - it’s working now!!!
