Newbie
Sandisk Clip+ will not turn on and canot connect with MSC mode - help!
[ Edited ]
HI,
I have loaded a rather large FLAC file onto my sandisk clip+ and it appears to have screwed it up!
When i press the power button it just freezes on the opening screen - when i assume it is refreshing the database?
I have tried holding the centre buttun as i connect to a PC in MSC mode but again nothing happens?
Any ideas anyone?????
Cheers
(sandisk clip+ 8gb model)
SanDisk Guru
Re: Sandisk Clip+ will not turn on and canot connect with MSC mode - help!
Hld the power button down for at least 30 seconds to reset the player.
Newbie
Still no luck, held power button for over 30 second, then conencted to pc holding centre button, nothing just stalls on sansa logo on the second opening screen.
when i just turn on  it does exactly the same, stallson the logo??
any ideas
Newbie
[ Edited ]
I'm having exactly the same problem, although I don't have a large file to contend with. I was playing an audiobook which has a lot of small files. All of a sudden the power went down and I haven't been able to get it started up again. I thought perhaps I might have accidentally locked it, but it didn't respond at all.
Doing the 30-second reboot thing at least brought the screen back but like yours it got stuck on the fan-shaped picture.
I held down the middle button and plugged it in. The computer is only reading from my memory card and claims that the Clip memory needs to be reformatted before it can be used. I disengaged the memory card, and put it in another slot to check it. Now the computer thinks it can't be ejected safely because another app is using it.
"My computer" (Win 7 32bit) is now not responding. Lovely.
Newbie
[ Edited ]
OK -- just unplugged it from the computer... "My Computer" is happy again. But now the Clip doesn't turn on. I held down the power button again for 30+ seconds... not even a fan, now.
Grumble.
Held the power button AND the middle button down for 30+ seconds. Why not... Hm, it rebooted!
The files are definitely corrupted. At first, it didn't want to read the disk, then it hesitated and gave me a directory listing. So, OK, I'll need to reformat. I went to turn it off and it's hanging on the "goodbye" screen.
<tries trick again... no luck>
Yup. Stuck with the fan, not able to connect to the computer. Meh. I was listening to a mystery and I want to know who did it!!
Newbie
Wow, spanky.
With the device connected to the computer again I held down the middle button and the power button. I got a "hey man, you need to reformat this, ya wanna?" pop up. Sure! Let's do that.
But sadly it's unable to reformat, and this is where I say YARGH!! and give up for a while.
Newbie
I still having nothing with mine, despite holing every button down.
I think its just really poorly written firmware from Sandisk.
Anyway am returning mine and I think I will put rockbox on it instead! can't be any worse!
good luck with reviving your sandisk
Newbie
yep. same thing's been happening to mine for 2 days now.
i left it sitting off for 3 hrs, turned it back on and it worked. connected to pc and it constantly connects and disconnects, rendering it impossible to add or remove more files.
p.s. whenever i have a microsd card inserted. it gets stuck at refreshing media. and if i leaving it off, inserting the card, connecting it to pc, and then turning it on, it doesn't even respond.
i would send it back for a replacement, but i can't find my original packaging materials with the warranty papers and stuff.
i've been using this sansa clip+ for about 7 months
SanDisk Guru
You don't need your original packaging, etc.--just, presumably, your receipt showing purchase date (U.S. warranty--1 year; EU--2).
Newbie
really? just the receipt? awesome!!!
and what if it was an online purchase from an electronics store, like newegg (as opposed to ebay or amazon or one of those general sites)?
same deal?
