Newbie
Rockbox
I'm using a 4gb clip +  via a mac with a 16gb card. I'd like to try Rockbox, usb is set to msc and firmware is v01.02.15a.  How will Rockbox improve the use of the clip in music/podcast/audiobooks, and what should I do before the switch?
Thanks,
Scott
SanDisk User
Re: Rockbox
http://www.rockbox.org/wiki/WhyRockbox.
Before the switch, you should read the first two chapters of the manual.
http://download.rockbox.org/daily/manual/rockbox-sansaclipplus/rockbox-build.html.
SanDisk Guru
Re: Rockbox
How do you know you'd like to try it, if you know nothing about it?
You need to spend some time at the Rockbox site.
Newbie
Re: Rockbox
Of course Rockbox is fine for info but those here are die hard fans of the clip so I went to you first.  Thanks for the reply...
SanDisk Guru
Re: Rockbox
[ Edited ]
It all depends on what you expect or want to get out of it. The majority of people are perfectly happy with the way the players work with their origiinal firmware. If however, you're looking to tweak every setting (beyond the basics) or more options than you can count then Rockbox is the way to go.
The manual is invaluable, both in installing it and the countless options avaliable, how they work and how to set them up. I'd suggest downloading the .pdf version of it and keeping it handy on your computer for future reference. You'll find yourself going back to it a lot while you learn.
SanDisk Guru
Re: Rockbox
And it's beyond just tweaking:  Rockbox gets some things right which the OF just, well, doesn't.  E.g. no file limit and no obstructionistic database refresh (argghh!!).
SanDisk Guru
Re: Rockbox
Battery life also improves. Smiley Wink
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
SanDisk User
Re: Rockbox
Is the sound quality about the same or better?
(for MP3 only or all codecs?)
SanDisk User
Re: Rockbox
The sound quality is about the same.  You should, however, be aware of the issues.
http://www.rockbox.org/wiki/SansaAMS#AMSv2_issues_40Fuzev2_44_Clipv2_44_Clip_43_44_ClipZip_41:.
Another thing you might be interested in knowing is that Rockbox’s five-band parametric equalizer is a lot better than SanDisk’s equalizer, which is non-parametric.
SanDisk Guru
Re: Rockbox
Aside from things like EQ (which rockbox does do a lot better), pretty much all software is supposed to produce the same output for an mp3 file. There is a spec. If something produces different sound then the spec requires, its not really better or worse so much as it is "broken".
