Highlighted
SanDisk Professor
Rockbox gives better battery life -- how come Sansa's firmware doesn't?
OK, Rockbox runs great, but I have a confession to make:  I actually prefer the Clip+ original firmware (o.f.)  It's simple, uncluttered, and intuitive.  Rockbox takes more buttons and menus than the o.f. to find and play my music, and lots more buttons to find and set options.  But there's a HUGE reason to use RB, and that's battery life -- the battery lasts a whole lot longer running RB than o.f.
So, two questions.  First, has anyone actually benchtested a comparison of the battery life of RB vs. o.f.?
And second, if Rockbox can achieve better battery life, why can't Sandisk?  This is, obviously, a firmware issue.  Why hasn't Sandisk fixed this?  They'd sell more players if they could advertise a longer battery life, right?
Is this the right room for an argument?
Highlighted
SanDisk Guru
Re: Rockbox gives better battery life -- how come Sansa's firmware doesn't?
well i can answer the question in your sig. when you hit 800 posts
Highlighted
SanDisk Guru
Spoken like a true guru ...    Smiley Wink
Highlighted
SanDisk Guru
[ Edited ]
  is your friend. http://www.rockbox.org/wiki/SansaRuntime
It is a firmware issue. Just one example....FLAC sucks the life right out of the battery when running in the Sansa firmware.....typically a 40% drop compared to MP3, in my experience. Yet in Rockbox, the Clip+ will play longer in FLAC than in MP3.
You ask, why hasn't SanDisk fixed this? That, I cannot answer. There are limits even to a Guru's knowledge. Smiley Wink
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
Highlighted
SanDisk Guru
I guess you were right, Marvin. I was remembering it was 900, but seems I was mistaken.
My feeble, old Guru grey matter just ain't what it used to be. Smiley
Highlighted
SanDisk Guru
I think this is true for basically all formats except mp3, where the OF does pretty good and shouldn't be much less then rockbox.  If you're using mp3 and like the OF, I'd probably just use it, at least for now.  I'm working on more mp3 stuff which will hopefully put rockbox further ahead, but its still a little off.  Plus theres other stuff in rockbox that still wastes some power that needs fixing.
Its a lot of work for small gains.  Plus its very hard for companies to do this sort of optimization since they usually buy their decoders rather then write them.  We have the advantage in that mt, linuxstb and I wrote some or even all of the bits in most of the rockbox decoders.  Doing that took us years, but now we have really good decoders that we can optimize as much as we like.
