I am trying to reset my Sansa clip. The support site says push and hold “Power/Menu button” for 20 seconds. There is no “power/menu” button on the clip. There is a power button, there is a home button, a select button and a “home” button.
I am trying to reset the clip+ because although I deleted all of the music, the album titles remain. The player will not accept new music, nor play the music for which the album titles still appear.
:manmad:
I’m assuming you actually want to format your player (holding power to reset it is for when its frozen). Its under settings > system settings > format. That will restore your player back to its original state by deleting everything.
To reset the Clip+, you hold the power button down for 20-30 seconds (or more).
Resetting will not help this. Format it as Saratoga suggested.
