Newbie
Questions about playing from microSD card
We have some questions about using the MicroSD card:
1. Does playing from MicroSD card drain battery life quicker than if playing from the Clip+? If so, how much more?
2. Is playing stuff from MicoSD card slower to access compared with from the Clip+? Are there gaps when going from one track to another?
SanDisk Guru
Re: Questions about playing from microSD card
I don't notice any difference in access time between the microSD card and the player's internal memory.
And my hunch is that there is no significant difference in battery consumption--but others may know better.
Newbie
If other people can confirm the answer here, that would be great.
Thanks.
SanDisk Guru
Thanks.
That's an answer from a Sandisk Guru.  Is there more that really needs to be said?   Smiley Wink
And for a second opinion, I agree with Miikerman.
SanDisk Guru
@mags1230 wrote:
Thanks.
I'll third that opinion.Smiley Happy
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
SanDisk Guru
@Marvin_Martian wrote:
@mags1230 wrote:
Thanks.
Count me in too!
Newbie
What makes one a SanDisk guru?
SanDisk Guru
That's an ancient Chinese secret. Smiley Wink
SanDisk Guru
As far as I'm aware, pure longevity here (that is, number of postings).  Not based on genius, I can assure you (speaking personally, that is ...).
SanDisk Professor
You become a guru after making lots and lots of posts.  I too aspire to guru-hood.
Is this the right room for an argument?
