Problem with Folders On my sansa clip4gb
Hey guys
I just bought a new sansa clip 4gb Because my father washed be my mistake the older one.
Anyway In the last clip,(which was exactly the same,besides the color).I’ve putted folders,than went in the player
to music>folders, and there I could see what i’ve putted on the player,with the same name Of folder.
In the new player i’ve putted the same,went to Music>folder than appear MTP,which is just making longer way,instead of showing the folders right away,After I enter “MTP” I see the folders not even in english,Just at numbers and other letters.
Someone know how to fix this and delete this “MTP”
Thank for anyone who’s trying to help.
Ok guy’s I searched for some selution here And I fixed the Name of folders.
But Do anybody know’s how I can go Music>Folder and than to see my folders?without getting into “MTP”
and than only to see the folders?
thank’s ahead =]
Sure, just set the player to MSC mode instead of MTP (or Auto Defect).
Note that your computer can only see the files that were added in the mode that it is currectly connected in, so you should wipe everything off, set the player to MSC mode, then re-load everything.
