Newbie
Accepted Solution
Playlist problem
I'm creating playlist on a clip+ player with osx. I use the command line so I'm sure about the content.
the playlists work ONLY when the playlist file are in the same folder of the playlist file;if I try to add to the playlist files that are in subfolder they will not be showed when I open the playlist on the player, while I can use the same playlist on my computer (vlc, cog, itunes...)
Is it this behaviour normal ? it'd be quite useless to make playlist that cannot contain files that are in subfoleders....
Cheers
SanDisk User
Re: Playlist problem
In your playlist, are the folder listed as part of the path to the file?  For example this is a playlist I have (this is in m3u format):
#EXTM3U
#EXTINF:163,Melissa Etheridge - Come to My Window [Live]
Various Artists\The Concert for New York City Disc 2\05 Come to My Window [Live].wma
#EXTINF:309,Melissa Etheridge - Born to Run
Various Artists\The Concert for New York City Disc 2\06 Born to Run.wma
#EXTINF:216,Melissa Etheridge - Refugee [#]
Melissa Etheridge\Greatest Hits- The Road Less Traveled\01 Refugee [#].wma
#EXTINF:288,Melissa Etheridge - Similar Features
Melissa Etheridge\Greatest Hits- The Road Less Traveled\02 Similar Features.wma
#EXTINF:326,Melissa Etheridge - Like the Way I Do
Melissa Etheridge\Greatest Hits- The Road Less Traveled\03 Like the Way I Do.wma
#EXTINF:234,Melissa Etheridge - Bring Me Some Water
Melissa Etheridge\Greatest Hits- The Road Less Traveled\04 Bring Me Some Water.wma
#EXTINF:198,Melissa Etheridge - You Can Sleep While I Drive
Melissa Etheridge\Greatest Hits- The Road Less Traveled\05 You Can Sleep While I Drive.wma
#EXTINF:276,Melissa Etheridge - No Souvenirs
Melissa Etheridge\Greatest Hits- The Road Less Traveled\06 No Souvenirs.wma
#EXTINF:265,Melissa Etheridge - Ain't It Heavy
Melissa Etheridge\Greatest Hits- The Road Less Traveled\07 Ain't It Heavy.wma
#EXTINF:256,Melissa Etheridge - I'm the Only One
Melissa Etheridge\Greatest Hits- The Road Less Traveled\08 I'm the Only One.wma
#EXTINF:216,Melissa Etheridge - Come to My Window
Melissa Etheridge\Greatest Hits- The Road Less Traveled\09 Come to My Window.wma
#EXTINF:236,Melissa Etheridge - If I Wanted To
Melissa Etheridge\Greatest Hits- The Road Less Traveled\10 If I Wanted To.wma
#EXTINF:328,Melissa Etheridge - I Want to Come Over
Melissa Etheridge\Greatest Hits- The Road Less Traveled\11 I Want to Come Over.wma
#EXTINF:279,Melissa Etheridge - Angels Would Fall
Melissa Etheridge\Greatest Hits- The Road Less Traveled\12 Angels Would Fall.wma
#EXTINF:240,Melissa Etheridge - Lucky
Melissa Etheridge\Greatest Hits- The Road Less Traveled\13 Lucky.wma
#EXTINF:261,Melissa Etheridge - Christmas in America [#]
Melissa Etheridge\Greatest Hits- The Road Less Traveled\14 Christmas in America [#].wma
#EXTINF:264,Melissa Etheridge - Piece of My Heart [#]
Melissa Etheridge\Greatest Hits- The Road Less Traveled\15 Piece of My Heart [#].wma
#EXTINF:215,Melissa Etheridge - This Is Not Goodbye [#]
Melissa Etheridge\Greatest Hits- The Road Less Traveled\16 This Is Not Goodbye [#].wma
#EXTINF:261,Melissa Etheridge - I Run for Life [#]
Melissa Etheridge\Greatest Hits- The Road Less Traveled\17 I Run for Life [#].wma
EricB
Newbie
Yes, there is the complete path to the file, without the folder MUSIC, like your playlist - the only differece are the slashes: on os x and linux the slash is "/", while on windows is "\"
I've tried to convert the slash and now the playlist works... not that great, but at least I know why Smiley Tongue
Thanks for your answer!
SanDisk Guru
Figures Apple would be bass-ackwards . . . or is it Windows? Smiley Tongue
Newbie
it's just a different standard, and we could talk a lot about it, but that's not the point.
In this case, sandisk should support both the slashes - I hope in a future firmware update Smiley Happy
