Highlighted
Newbie
Accepted Solution
No sound progress bar not moving
For some odd reason i'm not getting sound out of my clip and the progress bar doesn't move on any songs. It was working just the other day. I'm sure it's something i did but can't for the life of me figure it out. It's NOT on pause the > is showing not the = pause sign.
Highlighted
Newbie
Re: No sound progress bar not moving
Problem solved. Installed the firmware upgrade and put my music back on. It's all working now.
Highlighted
Newbie
Highlighted
SanDisk Guru
lennybee, please elaborate as to your situation/how you're playing your player/what you've done/etc.?
Highlighted
SanDisk Guru
Lennybee appears to have been struck speechless from the plethora of information and unrivaled support he found here on the forum.
Smiley LOL
