I’ve used Sansa Clip + units for years. My last one has finally died(bad jack). Regrettably, Sansa no longer makes the Clip + and buying one of the few units available is cost-prohibitive.
I want to transition to a newer unit that a) works on Mac, and b) uses playlists similar to the Windows Media Player lists I’ve used for the Clip + all these years.
Does Sansa make a unit that fits those criteria? Thanks in advance.
