Newbie
Re: My Sansa clip+ won't turn on what so ever
Leaving it plugged for 2 days didn't help Smiley Indifferent I have to throw it away.
SanDisk Guru
Leave it alone for a few days, as Saratoga suggested. Believe it or not, this sometimes works.
SanDisk Guru
And sometimes leaving it plugged in and not in use for a few days (2-3) can help--the trickle charge gets the player up and running again.
Newbie
Dude. I don't know if I've ever been so relieved. At first I held it for a minute I'm like "it's not working.." so I let go of the button and sat there. And I decided to try again and it turned on right away!
So it will take 3-4 hours to fully charge? Man. But thank you SOO much for helping me!!!!!!!! I've NEVER been happier!
SanDisk Guru
About 3 hours to charge it--the battery icon on the player's screen will show as full.
Congratulations!   Smiley Happy
Newbie
thank you....my sansa clip would not turn on as well...i thought it was toast...ruined my day...almost threw it away...decided to check the web and it turned on after the suggestion....whew life saver,lol
Newbie
I am having the same problem.  Was playing it earlier, turned it off, now it won't come back on.  Tried the reset options multiple times and nada.   This seems like a recurring problem for this device.
Newbie
just wanted to add that my player would not reset until I removed the micro sd card. It reboots then put card back in no problem.
SanDisk Guru
Interesting extra detail--thanks for the report!
Newbie
Oh, thank goodness. I've had it for a year or two with no problems. I charged it overnight, then my kids messed with the computer, and it wouldn't turn it on anymore. After I held the power button down, I had to do it again a couple times. It seems good now.
