Newbie
Accepted Solution
Manual playlist not recognized
Greetings,
I have bought a clip+ a few days ago. The mp3 files are played in a complete disorder. I wanted to create a playlist so I followed carefully the instructions at http://kb.sandisk.com/app/answers/detail/a_id/224/kw/playlist and I put the playlist in the same folder where the mp3 files are. With notepad I can confirm that the playlist contains all the file names with extension. But when I try to access it from the clip+ menu it says "empty list". How is it possible? What am I doing wrong?
Thanks in advance.
SanDisk Guru
Re: Manual playlist not recognized
I'm not at all a playlist dude. But one thing I wonder is, are the ID3 tags for your files in place and as they should be? MP3Tag is a nice freeware tag editor for this purpose, including to check the files and tags out. http://www.mp3tag.de/en/
SanDisk Guru
And MP3Tag will also create playlists for you (under the File menu). I haven't tried it myself (I'm at work and brought my Clip+ cable instead of the Zip's cable with me) but you might give it a go.
Newbie
Thank you for your answers. I had no time to try today, too busy at work, but will certainly try your suggestions during the weekend. Right now, I just wanted to thank you for your suggestions.
Newbie
OK, I could create the playlist thanks to the MP3Tag software. I have 25 files in the correct order in the playlist. When I select the playlist, Clip+ plays them in a completely wrong order.
No. 1
No. 18
No. 25
No. 24
No. 21
No. 10
No. 22
No. 19
and so on. But in the playlist the numerical order is correct. What am I doing wrong?
Newbie
Never mind, I have the shuffle "on", sorry! Problem solved, thanks!
SanDisk Guru
Smiley Happy
