Highlighted
Newbie
Low Volume
Hi there
How can I setup the volume LEVEL? IN FULL VOLUME IS STILL TO LOW
Highlighted
Newbie
Re: Low Volume
I would update to the latest firmware if you already haven't. I would also check to see if you haven't set the volume limit to 'normal'. There is a setting that will allow you to change the volume limit from 'normal' to 'high'
Highlighted
SanDisk Guru
Re: Low Volume
Did you read the 5th sticky post/thread down from the top of the page entitled No More High Setting in Music Volume?
Highlighted
SanDisk Guru
Re: Low Volume
If you are in the EU or installed the firmware using the EU as the region, you don't have a High volume option under settings, due to EU governmental restrictions on volume.
The solution:  reinstall the firmware (see the firmware upgrade sticky thread at the top of the forum) and choose another region, such as Rest of the world, and then go to the player's settings under volume and choose high volume.  Or, just choose Reset factory settings under the Clip and likewise choose a region other than the EU.
Highlighted
SanDisk User
Re: Low Volume
You can substantially increase the volume of Clip+ by tinkrting with the (Custom) settings of the Clip Equalizer -- perhaps by boosting the mid tones.  Careful -- too much volume might lead to distortion.
