SanDisk User
Accepted Solution
Charging Sansa Clip + Question (With mini USB charger of mobile phone)
i have some question about charging issue :
  • is it okay to charge clip + using mobile phone charger with mini USB jack (5v ~ 700mA), as i know, USB 2.0 spec is 5v ~ 500mA ?
  • is sansa have a circuit to handle charging process, for example cut-off the current when battery fully charged ?
  • after several hour connected to the computer, the display turn of itself... is it normal ? (so i have to press any button to see the screensaver and check the charging status)
thanks for answer my question... hehhe Smiley Happy
SanDisk Guru
Re: Charging Sansa Clip + Question (With mini USB charger of mobile phone)
Yes, yes, and yes.
SanDisk User
gwk1967 wrote:
Yes, yes, and yes.
wow, short and complete answers.... hehehhe
as my question is too long.... hahha.....
hemmm... how many hour clip+ can stay unplugged ? (in a real world) ~ not 15 hour by Sandisk.
SanDisk Guru
When charging, to help preserve the display, the display turns off after, I believe, an hour.  As you saw, pressing a button on the Clip starts the display up again.
Battery duration depends on lots of factors:  file type, button pressing, volume, etc.  People often report in the 10 or 10+ hour range.
SanDisk User
okay, now i'm sure i can use any miniUSB charger, because clip+ has its own circuit to handle charging process....
i'm going to make a customised usb cable, with disabled Data pin, so i can charge clip+ via computer and i can use it while connected. is it hurt my laptop's USB ? cos USB port can't communicate with USB device about how many current to give .
i love my clip+ much, so i have to use it carefully .... hahahhaha
SanDisk Guru
You can use any charger, but be sure it is 5V and not above that (above will fry your Clip).  Around 350mA and above (although around 500 mA and above is better) is fine--the Clip will use the amperage it needs.
Yep, you can disable the data pins and everything should be ok.  Just be sure you know what you are doing as to which pins.  Many people report being able to get to the same end just by not fully inserting the USB cable into the computer, or by covering the data pins.  Also, you can buy charge-only USB cables--I have a couple of those.
Note that when you connect to your computer, you still can play the Clip's files, via the computer itself (not the Clip) and media playing software that is pointed at and playing the songs on the Clip.
SanDisk User
so, 5v ~ 700mA is okay for my clip+...
btw, thanks for ur fast response & answers....... Sandisk Forum is one of the fastest response among another forum....
thanks Sandisk to provide this forum, so we can share our knowledge about Sandisk product...
bravo Sandisk...
SanDisk Guru
Happy to help (and thanks for the thanks)--we're both online at the same time.
Your charger should be fine, for the Clip and other accessories.  Personally, I always like a charger that is for 500 mA and above--gives you versatility to use it for other products as well.
Newbie
If most people say the clip+ stays charged for about 10 hours ...how come mine plays for about 3 hours?!
Should I charge it more or less than 3 hours?
Please help me, I need around 7 hours for my bus tripsSmiley Sad
SanDisk Guru
Many things can affect battery life . . . format of files being played, volume, backlight, fiddling with the buttons, etc.
