I wonder if there is a bug fix for this problem. I can’t transfer files larger than 200 megs from the Sansa Clip+ onto my computer (Win XP). I don’t use syncing; I prefer to drag and drop or copy onto a windows file folder, and every time this happens( "Error copying File or Folder Not enough storage is available to complete this operation), I have to PLAY the file into the computer using a line-in to USB audio interface device which is DRACONIAN with respect to a real time bottleneck. Does anyone else have his problem? Is there a bug fix, or another remedy (short of reformatting) that would cure this dilemma? Thanks in advance.
