Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
![]() How to charge ixpandOptions
11-07-2015 03:09 AM can someone tell me.. To charge ixpand, I know I can plug into computer. But can I also use the apple plug... Remove the cable used for iPad and plug the ixpand into it? Apologies in advance if I post this incorrectly... New to this Solved! Go to Solution. ![]() Re: How to charge ixpandOptions
11-07-2015 12:43 PM Are you referring to the AC chager that comes with an iPad or phone? If so, yes you can use them to charge it. |
