Highlighted
Newbie
Playing DTS doesnt work
hi
just bought iXpand USB3 - and i've tried to move a 5 gigabyte mkv clip but i've got an error msg  that said "the file is too big"
so i format the DOK to exFAT.
after that i've tried to play MKV clip with DTS sound and it doesnt work at all ...
can you assist me  ?
Highlighted
SanDisk Guru
Re: Playing DTS doesnt work
he app does not support dolby audio codecs
http://kb.sandisk.com/app/answers/detail/a_id/18851/
The (iXpand and Connect) apps do not currently support certain audio / video formats, such as those encoded with AC-3 (Dolby Digital) codecs. In some instances, you may be able to select the file and use the “Open in” feature to use other apps on your device that support such formats to playback these audio / video files.
SanDisk values the opinions and concerns of our users. We would like to invite you to take a short survey regarding video playback issues.
Take the Survey Now
