Directories
Can you plug in the ixpand into your iPhone X and create a directory to put your stuff in? or you can only do that on the computer???
I see you can delete directories and files.
Thanks
hen you copy files to the ixpand from the iOS device you have to select a destination for the file. You can select an existing directory or create a new one.
Thanks
I got it.
to put your stuff in? or you can only do that on the computer??? I see you can delete directories and files.
@britany wrote:
to put your stuff in? or you can onl [uc browser](uc browser) y do that on the computer??? I see you ca filezillan delete directories and files.
I see you can rufus delete directories and files.
