Highlighted
Newbie
Accepted Solution
XPS8700 doesn't recognize ULTRA II 480G
My Dell XPS8700 desktop doesn't recognize my Sandisk Ultra II 480G SSD.  I am running Win 8.1.  The Sandisk SSD Dashboard can't find the SSD.  It is connected to the SATA port 2 and I have checked the power and SATA connectors.  Any ideas?
Highlighted
SanDisk Professor
Re: XPS8700 doesn't recognize ULTRA II 480G
did you format the ssd inside the disk managment in order to initialize the drive and create the partitions on it since all the ssds come unformatted and you need to format them before using them normally on the computer.
Good Luck
#Missing the keyboard? Press F1 for help#
Highlighted
Newbie
I tried to format the SSD using a USB connector and it still was not recognized.  Thanks for the suggestion because now I know the SSD was DOA and I'm sending it back.
