Newbie
Sandisk Ultra II vs Samsung 850 Evo
Ok, so I'm upgrading my old laptop with an SSD, as that's the main thing slowing it down right now. After the upgrade, I'm going to keep using it as my main computer for another nine months or so, and then I plan to buy a new $1000 computer hopefully with 16gb of ram, 4gb or graphics memory, 500gb ssd (or more), etc.
This upgrade that I'm doing right now is basically a nine month band-aid. My current laptop's HDD only has about 300gb of capacity anyway (283 partitioned as the C drive), and I've only used about 140gb of it. Hence, I'm ok with settling for a 250gb SSD as opposed to a more expensive 500gb SSD, which would be about $60 more. I'm on a pretty tight budget.
Newbie
Re: Sandisk Ultra II vs Samsung 850 Evo
@Siddharthpatil wrote:
Ok, so I'm upgrading my old laptop with an SSD, as that's the main thing slowing it down right now. After the upgrade, I'm going to keep using it as my main computer for another nine months or so, and then I plan to buy a new $1000 computer hopefully with 16gb of ram, 4gb or graphics memory, 500gb ssd (or more), etc. new projects in mumbai
This upgrade that I'm doing right now is basically a nine month band-aid. My current laptop's HDD only has about 300gb of capacity anyway (283 partitioned as the C drive), and I flats in dadar 've only used about 140gb of it. Hence, I'm ok with settling for a 250gb SSD as opposed to a more expensive 500gb SSD, which would be about $60 more. I'm on a pretty tight budget. property in mumbai
Any Updates???
