Newbie
Sandisk SSD Ultra 120Gb und Medion Akoya P 7350 D (MD8860).
Ich habe gestern oben genannte SSD Festplatte geschenkt bekommen. Bei mir ist eingebaut eine Seagate Barracuda SATA 3 1000 Gb. Jetzt ist meine Frage: Lohnt sich überhaupt  in mein Pc o.g. SSD einbauen( als System Disk)???
Danke im Voraus.
SanDisk Professor
Re: Sandisk SSD Ultra 120Gb und Medion Akoya P 7350 D (MD8860).
i think it would be better if you would post your issue/question in English so all of us can understand what you are talking about.
Good Luck
#Missing the keyboard? Press F1 for help#
Newbie
Yesterday I get paid above SSD hard drive. When I installed a Seagate Barracuda SATA 3 Gb 1000. Now my question is: Is it worth at all in my PC og SSD install (as a system disk) ??? Thanks in advance.
SanDisk Professor
in that case where your system supports a SATA 3 connection then you can for sure upgrade to an SSD drive. you will see much higher speeds with this drive and also less power consumption and noise.
so go ahead and install it in your system to enjoy higher speeds Smiley Happy
Good Luck
SanDisk Guru
If you in fact have the SanDisk Ultra SSD and not an Ultra II SSD, it is only SATA 2.
