Hi!
1.- Sorry for my english, i don’t write very well. I have a low level of english.
2.- Question:
I can’t delete one carpet in my drive. I see the carpet in windows explorer, but i can’t delete…
The massage say: “El elemento ya no está ubicado en la unidad” - "This element is no longer in this drive C:"
Do you think this is a SSD problem? or maybe a Windows Problem?
3.- Problem:
I can’t play mare than five minutes one game. “No man’s Sky”. The game crashes and freeze the computer. I check the VGA, RAM, and power suply and are OK, but i can’t check the SSD Unit.
I download some programs like: “SanDisk SSD Toolkit”, “SSDlife Free” and “HDD Guardian”, but i don’t find any program to check the good work of the SSD unit…
My SSD Unit is:
Model: SanDisk Ultra II 480GB.
Serial Nº: 160710803975.
Firmware: X41100RL.
Version ATA: Reserved (ATA8-ACS)
Sata Generation: 3
Mundial names: 5001B448B4461846.
Compatibles functions: DSM (TRIM), SMART, Security, NCQ, APM.
Can i download any software to check, the SSD Unit? Where?
Thank you for your atention.
Best regards
Scar Cp.
