Newbie
Accepted Solution
What speed should I be getting?
Hello, Iv just upgraded my sons old desktop with an ultra 3d 250gb I am getting read/write speeds of 239mb/s I also tried an ssd plus 480gb which is getting about the same speeds,I think I was getting about 136mb/s from the hhd.I was expecting to get a lot faster speeds or is that the speed to be expected on an old desktop running w10pro 32bit 4gb amd 9550 cpu,thanks
SanDisk Guru
Re: What speed should I be getting?
what SATA chipset is in the computer? if it is a SATA II 3Gb chipset the speed you are seeing is normal.
Newbie
hello,it is a SATA II 3Gb chipset, is that something you can upgrade or is it parts of the motherboard,thanks
SanDisk Guru
no, you would need a new motherboard.
Newbie
OK thanks drlucky
