Hi.
22 hours ago i purchased SanDisk Ultra USB 3.0 32 GB with SecureAccess V 2.0 protection.
i run the installation once i plugged it in give me a notification for an updated version, downloaded and ran, and opened the USB and everything went fine, i started backing up some files on it (Large size Family pictures and Videos). all went well for the first gigabytes; but then it started giving me some errors declaring he can’t copy this file or that file (most of the files are videos around 500 mb’s each). i neglected these errors and kept copying my files.
next day was still doing my backups, left the device copying some files, and returned to find the same error, closed it and checked the SecureAccess and it was un-openable… checked the usb to safely remove it and it was not read as connected at all. so i decided to fully shutdown the pc and restart it afterward… did that and since then the SecureAccess is not working, when i go into the UFD and double click the windows program it gives me this message :
“SanDisk Secure Access V2.0 is not able to write to the usb flash drive. Please check that the drive is not write protected and in case you are using a Guest account, make sure you have write permission for this drive. Click OK to close SanDisk Secure Access V2.0”
knowing that i am an Administrator on this pc. and that YES the drive is write protected "Duh !! "
when i try to overwrite/delete the SanDisk Secure Access file on the UFD (As i read online it was solving some issues). it gives you can’t write on this drive as it’s write protected.
When i try to format the whole drive it gives me the same message.
so for now , after 24 hours from the purchase, the UFD is totally unusable for me, and the Security software seems hugely buggy :\
Stats :
My device that i USED :
HP Laptop
Windows 8.1
Core i7, 6 GB Ram,
UFD : SanDisk Ultra 32 GB
Ports used : USB 3.0 & USB 2.0
ANY YES i tried another PC
