Highlighted
Newbie
SecureAccess 2.0 error please help!
When I am copying files to a SecureAccess 2.0 vault on my 128GB Extreme, it goes along fine for a bit and then I get a popup error which says: Cannot open file for write F:\SandiskSecureAccess Vault\{.....}.dat Error:The directory or file cannot be created. When I click OK, the copy process stops and it ends. I have tried reinstalling SecureAccess 2.0 after deleting everything. I have formatted the flash drive as FAT32 and reinstalled SecureAccess but none of this has helped. Any ideas? Thanks.
Highlighted
Newbie
Re: SecureAccess 2.0 error please help!
 I am having the exact same problem. SanDisk 128GB Extreme Pro using SanDisk SecureAccess V2.0.
Was working fine for the first two weeks, but now I get the following error when coping files into MyVault. "Cannot open file for write D:\SanDiskSecureAccess Vault\{4ce1b97b-a5a7-4457-9898-cc0390604b44}.dat
Error: The directory or file cannot be created" Properties (general tab)
Type: Removablke Disk
Filesystem: FAT32
Capacity: 128,004,390,912 bytes   119GB
Used space: 4,914,741,248 bytes  4.57GB
Free space: 123,089,649,664 bytes   114GB
Highlighted
SanDisk Guru
I fail to see how a spam link to a McDonald's survey site will help or have any relevance to this thread. Smiley Mad
