Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
Very bad 4K read speed, any idea why?[ Edited ]Options
09-02-2018 03:19 AM - edited 09-02-2018 03:29 AM
I replace the harddisk with Sandisk SSD Plus 240GB which I bought few days ago in my old samsung notebook NP350V5C. The notebook is running windows 10 Home 64 Bits version and the SSD is running in SATA 3. I have tried to use the Microsoft chipset driver, turn off the Windows Write-Cache Buffer Flushing, run windows safe mode. Any idea why the 4K read speed is so low? Thanks. Re: Very bad 4K read speed, any idea why?Options
09-02-2018 04:35 AM
I also run in high performance mode, check partitions are correctly aligned. All these cannot help.
