Newbie
SanDisk SSD Plus 1000GB S.M.A.R.T tests not running - why?
I'm running Windows 8.1 with the SSD Plus as boot drive.
Windows event viewer shows lots of error messages:
"Bad block with device\Harddisk0\DR0"
SanDisk SSD Dashboard 2.5.1.0 does not show any problems, but when I try to start the short or extended S.M.A.R.T. diagnose tests both fail (i.e. the test itself fails - not the disk).
As I'm a bit worried by the Windows event writer messages, what should I do next?
Titus
Newbie
Re: SanDisk SSD Plus 1000GB S.M.A.R.T tests not running - why?
same problem here...but worst
https://forums.sandisk.com/t5/SanDisk-SSD-Plus/SSD-100-usage-time-0-W-R-S-M-A-R-T-test-short-and-lon...
if sandisk did not present a solution....sandisk never again
