Hi, if i try to make backup on my sandisk 8gig ultra sdhc 1 card, all work fine. But i would like to make my backup on my dropbox service and it fail. When i start the backup it take long long time before start, make copy of 10 to 15 files very very slow and after, slow down and slow down again and after noting… i wait 2 day before stop the backup and try again. same thing. Can you help me please?
but it’s realy strange because i contact Sandisk by phone and he give me forums.sandisk.com address and said post your question because sandisk don’t support software by phone, only by forum web site…
first, thanks for your post. Correct me if i’m not OK but if I have uninstall and reinstall the application, the dropbox account have already delete and re-add? I have a Samsung Galaxy SIII (SGH-I747M) with Android OS 4.1.1
Has there been any headway on this issue? I have the same problem, it takes a long (LONG) time, then backs up a couple hundred kb and stops. The Time Remaining will show 146 hours (example) and the bw will fluctuate without any noticeable pattern. Stopping/restarting did not help. Sometimes, leaving the app running and returning to the home screen and then going back to the app will show an increase in bytes backed up (first time only). I assumed that this was the app updating the display and flushing the queue.
I have removed/re-added my dropbox account. There is plenty of space in my dropbox account.
i have the same problem, it’s very frustrating, i hope in a fast solution from sandisk, there’s a lot of different apps able to do the same operations without problems…
Hi, anybody have idea for me?? I have same problem event if i uninstall / reinstall, try other card, try other online service. I try speak to SanDisk by phone but i have for answer, post on forum!! More than 3 months and no solution for my problem… :mansad:
The problem I reported with the beta release 14.3.17 is based on the principle that no software, Dropbox included, should create files that break the standard functions of the manufacturer’s operating system. tellthebell.com
