Highlighted
Newbie
Re: Simple way to convert OST to PST?
If you prefer to have a tool which you can run single time on demand conversation you should defiantly take a look into https://www.osttopst.online/how-it-works
The tool is very intuitive and easy to use.
If you prefer a stand alone tool, there is also a version to download and install it.
The benefits of the online tool:
it works on any device that is connected to the Internet
- Can be run on any OS
- Does not require authentication by Windows Domain Controller
- Does not require access to a Microsoft Exchange Server
- Does not require you to have Microsoft Outlook installed on your device
Highlighted
Newbie
Recover OST to PST
Stella OST Converter is very helpful Software for converting large OST files to PST including with all internal elements contacts, task, calendars, journals, reminders and user defined folders. The main motive of software is to provide 100% saves and secures result in every situation. It provides multiple formats like as :-  PST, EML, MSG and HTML for users to save the OST Data effectively. The Recover OST to PST supports all Windows (10) and MS Exchange Server versions 97 to 2016.
Read More :- https://www.stelladatarecovery.com/ost-to-pst-recovery.html
Highlighted
Newbie
OST2PST Wizard is the simple way to convert OST files into Outlook PST files without taking any help of MS Outlook. This is the best OST to PST converter  on internet. There is no file-size limitation during the OST file to PST conversion process. It can also repair OST items along with OST file item such as email, task, notes, contacts, journal, etc. You can try it free to check the performance of this tool. check full info: https://www.ost2pstwizard.com/
Highlighted
Newbie
With the new OST to PST converter tool, one can convert easily convert the OST files to PST file format. It is one of the simple and easy way to convert OST to PST. The tool can exports password encrypted Outlook OST file to PST format in an easy and safe manner. One can save the exchange OST file to Outlook PST, MSG, DBX, EML, MBOX & Archive thus, providing migration flexibility. The tool also supports corrupted or damaged Exchange OST files hence, users can also convert corrupted Outlook PST files.
Highlighted
Newbie
Try PDS OST to PST Converter is amazing software for the OST data convert to PST. This software is embedded with multiple features for providing a better OST Conversion. This Software give a permission to preserve your Meta data and properties such as To, Cc, From, Date, Time, Subject and Object. Split the large or mega file into several small files without creating any size limitation issues. You are free to convert your data into various formats like PST, EML, MBOX, HTML, PDF and Office 365. Try the free demo version of the converter to convert 30 emails for free.
