Newbie
Sd card problem
I just bought a sandisk 64gb sandisk sdxc micro sd card. When i inserted it in my switch, it just didn't recognize it. It works perfectly fine on my computer tho. I tried putting in other micro sd cards but no luck either. I think my port might be broken or something. Also, I tried formatting the card to no avail. Could someone help me?
Newbie
Re: Sd card problem
Tips to Avoid Memory Card Error and Damage
  • Do not remove your memory card during photo saving and viewing.
  • Do not remove your memory card when turning on/off your camera.
  • Do not change your memory card when the camera is on.
  • Stop taking/viewing new pictures on battery low.
  • Use memory cards from big brands such as SanDisk, Panasonic, Sony, Kingston, vidmate, Lexar, Olympus and many more.
  • If several different memory cards get damaged in one camera, you ought to suspect there is some issue with your digital camera.
  • Memory cards have a finite lifespan. A typical flash memory card unit has approximately 10,000 write/erase operations. So it is better to throw away memory cards that have been used frequently for many years.
Newbie
Re: Sd card problem
[ Edited ]
I had to format my sd card. That helped. In your case, have you tried all those solutions mentioned at sandisk 64gb micro sd card not recognized disk partition papers instructions?
?  I used SD Association's Formatter (found the link in one of the older threads here - https://forums.sandisk.com/t5/Mobile-memory-professional-cards/FORMAT-64GB-MICRO-SDXC-PROBLEM/td-p/2...).
Newbie
Re: Sd card problem
Corrupt SD Card via Chkdsk:-
  1. Click Start on your Windows taskbar, and open “Computer.” ...
  2. Right-click “cmd” under Programs and choose “Run as administrator”. ...
  3. Press Enter and chkdsk will start checking your corrupted SD card and will then fix any corruption on the card.
look here cheap & best power banks
