Newbie
Interfacing WIFI SD card with normal microcontroller
Hi guys,
I want to use WIFI SD card in my general embedded system. My Controller supports SD-Card interface protocol and I can connect normal SD-Cards to my controller. But I was thinking to interface WIFI SD card instead of normal SD-Card in my project. Is it possible? Please guide me on this topic.
SanDisk Professor
Re: Interfacing WIFI SD card with normal microcontroller
you can maybe use another sd wifi card in that case but you have to keep in mind that the sandisk eye fi card transfers only jpeg files wirelessly and can be connected to one device at a time with a point to point connection
so maybe you want to choose another sd card for that project.
Good Luck
#Missing the keyboard? Press F1 for help#
