Newbie
issue with replacement ssd
Hi at the end of 2014 i built a new computer and installed an Ultra II sandisk as my boot drive (cSmiley Happy
4 months later the drive failed and i contact sandisk and they replaced the drive with an Extreme pro.
On a cold start the Extreme pro dosent want to boot right away, it hangs at the bios splash screen for a few, then reboots.
Some times it will do that twice (but usally once) then it boots to windows 8.1 .
Once its been running awhile i can reboot  and it will not hang at the splash screen.
Is there soming i can do to fix the intial start up hanging and rebooting ?
SanDisk Guru
Re: issue with replacement ssd
Have you updated the FW on the SSD? The FW update post is stickied at the top of this board.
Newbie
[ Edited ]
i think mine came with that version
