Newbie
Undetected BUG
i think Extreme pro has a firmware bug which will caused undetected BUG.
Several people have met the same tissue.
This scenario is very similar with Crucial M4 .
Please help to fix it as soon as possible.
SanDisk Professor
Re: Undetected BUG
Can you please be specific on what bug you are refering to in order to get a clear view and detail on it?
do you have any issues with the drive and you refer to a bug? or does it have to do with the ssd dashboard that does not show up correctly the drive?
Thank you
Good Luck
#Missing the keyboard? Press F1 for help#
