Newbie
Switching network adapters
Hi all !
So I have a situation here where i have to switch between two network adapters when i game or when i just use the internet, one adapter has low latency low speed , the other is high latency high speed.
Anyway, I’ve already written a “*.bat” file that switches between the two adapters when i run this .bat file.
Since I have a stream deck, I wonder if this is possible to develop using the SDK ?? I have a good programming background, i can probably do it if it’s possible , is it possible though? Anybody has done a plug-in for that before ?
Btw: I’ve tried simply just “Running” the .bat file using the streamdeck , but unfortunately, this script has to be run as administrator, I’ve failed to figure out how to do it in stream deck ...
All respect Thx
