Highlighted
Newbie
SSD Slowing down
When first booting the system the SSD Extreme pro is working fine. After about 1 hour use it starts to slow down.
My operating system is as follows:-
Windows 7 Ultimate, 64 bit operating system
AMD Phenom II X4 Processor
I have tried to use the SMART Test to see if that points to any probelms however it appears to run and i get a message "Diagnostic
test complete with a status code 2:
the message "Last run states None" as though the test was not run.
I have also generated a report but am unsure if this forum is the place to place it
If anyone can help me i woulw appreciate it.
Frank
Highlighted
SanDisk Professor
Re: SSD Slowing down
a SSD can slow down if the TRIM function is not enabled, but in that case since you are using a Windows 7 system the feature should be on. In that case i suggest contacting the Sandisk support to get an explanation what the error code 2 is and to see if the drive is maybe defective and needs to be replaced.
here is the contact information:
http://www.sandisk.com/about-sandisk/contact-us/
Good Luck
#Missing the keyboard? Press F1 for help#
