Newbie
Accepted Solution
SSD Registration Problem
Hello, i was registering my new ssd and i got an error which where saying that product number is invalid... i correctly wrote down but no success... what does that mean? it's no original ssd? Smiley Mad
SanDisk Professor
Re: SSD Registration Problem
in that case i suggest contacting Sandisk support directly so they can check if the serial number is valid and then add it manually into the system.
you can contact them through this link
http://kb.sandisk.com/app/ask/session/L3RpbWUvMTQ1MDY5MTEwOC9zaWQvM3c2YWJ3RW0%3D
Good Luck
#Missing the keyboard? Press F1 for help#
Newbie
i contacted them and then updated it... they said site hadn't been updated ecently. now my ssd is registered with 10 year of warrranty !
SanDisk Professor
Very good, so enjoy the long warranty of your drive
Good Luck
Newbie
[ Edited ]
same problem here 1/2/16.
I don't know if its the same issue or not, but if so, what's going on?  Shouldn't that be a real-time or at minimum overnight feed?  Plus, I bought the SSD 11/29/15, BEFORE the OP got the DB refreshed, which I would think would cover mine (unless amazon sold me a fake)
I did submit a ticket, but it's Saturday and it seems they don't do service in the weekend Smiley Sad
Newbie
Same here. Purchased on 12/28/2015, got it on Jan 2, 2016. Can't register it..invalid Serial#. Sent msg to Sandisk. It kind of bothered me for a minute or so since there are people making knock offs of these. It works okay though and cloned the Win 10 Toshiba drive to it.
Newbie
Did sandisk reply to you?
Newbie
Not yet but it might take 2 or 3 days for a reply according to Sandisk.
Newbie
[ Edited ]
hello, i contacted tham using online support chat, so they responded quickly and fixed my problem and said whenever i get any problem, contact them again... there is online chat someone, find it and they will update the database. they said that site hasn't updated recently...
Newbie
Sandisk sent email today (1/5/2016) stating they registered my 480 SSD.  I sent all the numbers off the disk in the email so they got my serial number and registered it for me.  The drive is installed and is doing fine on Win 10 upgrade from Win 7 Ultimate.
