Newbie
Missing TRIM schedule option
I've just installed my new Extreme Pro Drive and in dashboard I'm missing option to schedule periodic run. There is only option for TRIM: Enable windows TRIM.
I'm running Windows 8 x64 Pro.
Thanks for help.
Pavel Cisar
Newbie
Re: Missing TRIM schedule option
[ Edited ]
Use the "Optimise Drives" tool in Windows 8.1 to schedule a periodic run of Trim.
Are you on Windows 8 or 8.1?
If NO, A clean install of Windows 8.1 is recommended.
Newbie
Newbie
The removal of Trim from the dashboard is good decision.
