My Win 7 PC has Dashboard 1.4.1 loaded. My Extreme Pro 480GB drive is formatted by the Atomos Shogun File Recorder as ExFAT. I plug it into my PC and it doesn’t display any information. It detects it. I can see the light of the drive adapter flashing. Does Dashboard not work with SSDs formatted for this type of use?
as far as i know the drive needs to be in the native NTFS format in order the dashboard to detect the drive if its a normal retail drive. in that case i suggest formatting the drive on NTFS and then see if the dashboard detects it.
