Highlighted
Newbie
Sandisk Extreme 500-Portable SSD disconnects during operation.
My ssd connects and disconnects regurlarly.I have been facing this problem after few months I bought.I am unable to use my hdd.Can any one please suggest any solution.
I have also heard that theres a manufacturer defect in the hdd regarding the connector.I have important documents in my hard disk.I dont want they to be erased.Please suggest what should I do?
Highlighted
SanDisk Guru
Re: Sandisk Extreme 500-Portable SSD disconnects during operation.
if you have seen the same behavior on more than one computer backup your data and contact sandisk support to check the warranty status.
