Newbie
will the sandisk connect wireless stick work with an ipad2
I bought the stick for another reason which won't work.  I have anothe roossible use for it, to get stuff off an old ipad2 onto my PC.  will this work?  thanks for your help
SanDisk Guru
Re: will the sandisk connect wireless stick work with an ipad2
the app requires iOS 8 or higher. So if you have iOS 8 or anything higher it should work. That said what "stuff" are you trying to get off the iPad? Third party apps only have access to the camera roll. You can use the wireless stick to get anything off the camera roll but music or movies etc you would need to sync with itunes to get that data off.
Newbie
Thanks, that is exactly what i needed to know - I will check the IOS on the ipad, I think it is only photos they want to get off.
