Newbie
Wireless stick will not turn on
My wireless stick 32gb, will not turn on.  It just blinks (White, Green, Red, Green, Red...White, White).    Also, when plugged into a pc via USB it is not discovered.  Any ideas on how to access the files?
Thanks!
SanDisk Guru
Re: Wireless stick will not turn on
sounds like a bad drive. return it to the place of purchase or contact sandisk support for warranty return.
Newbie
It started acting this way after I left it in the PC and the PC went into sleep mode.  I suspect the OS (if it has such a thing) was corrupted.
Any ideas how to retreve the data off of it would be greatly appreciated.
Thanks
SanDisk Guru
you can try a hardware reset. If it still is not detected after this it sounds like a bad drive. If the data is important and not backed up anywhere you would have to send it to a data recovery company to get the data back.
Hardware reset
http://kb.sandisk.com/app/answers/detail/a_id/17549/
Newbie
Thanks, I have tried that several times.
