Highlighted
Newbie
Will Sandisk SecureAccess work on Sandisk Connect
i just bought a 128 GB Sandisk Connect wireless stick.
Secure Access loads up, the Vault shows, but it allows entry to the vault without even asking for the password.
Can anyone help?
Highlighted
SanDisk Guru
Re: Will Sandisk SecureAccess work on Sandisk Connect
SecureAccess is not built into the connect App. If you installed the PC version on the stick you will see the vault folder. This is the folder where the encrypted database files are stored. You would not be able to access the files that were encrypted using the PC because you need to actually run the PC application to decrypt the database files.
