Highlighted
Newbie
Turning on the wireless stick remotely
To save power, you have option to turnoff the stick in 15, 30 and 60 minutes automatically when idle. After it turns off, is there a way to turn it on remotely? Without having to push the "on" button on the stick manually?
Highlighted
Newbie
Re: Turning on the wireless stick remotely
I would also love to know an asnwer to this. I bought this device thinking that I could use the wifi and usb features at the same time only to now learn that that's hardware limited.
I need to now turn on and off the usb remotely at set intervals.
I hope you get your answer friend!
