Newbie
Sandisk 64 gb pendrive problems
Hello to all member
I am having huge problems with my sandisk usb 64gb stick
I copied severed files to my pendrive now when I am copying it to the computer it stops copying the files and stops
can anyone tell me what is happening with it
Newbie
Re: Sandisk 64 gb pendrive problems
the pendrive is 64gb wireless
I cannot copy files to the computer and also the pendrive says everything is ok and no problems
Newbie
[ Edited ]
Sometime this type of problem occur by the infected visrus. So always remember to connect any device with your device first scan it after use. If you have any big issue related to antivirus contact {removed}
Newbie
You need to check if your computer is infected with a virus? To make sure, you should bring it to the store to check
